Orbi WiFi 7 RBE973
Reply
Cannot create backup from NETGEAR GS724T configuration.
Rostam
Tutor
Hello,
I cannot create backup from NETGEAR GS724T configuration. Get an error
Can anyone help please?
Thanks
Model: GS724T|24-port Gigabit Smart Switch
Message 1 of 7
Accepted Solutions
Rostam
Tutor
Re: Cannot create backup from NETGEAR GS724T configuration.
I found a way to fix the issue. I had to use old versions of Internet Explorer to be able to do that.
Thank you!
Message 6 of 7
All Replies
DaneA
NETGEAR Employee Retired
@Rostam,
What is the current firmware version of your GS724T?
To backup the configuration file from the GS724T, on the web-GUI, go to Maintenance > Upload > HTTP File Upload.  On the File Type list, select Text Configuration and click Apply.
To restore the configuration file to the GS724T, on the web-GUI, go to Maintenance > Download > HTTP File Download.  On the File Type list, select Text Configuration. Then, click the Browse button to locate the configuration file and click Apply.
DaneA
NETGEAR Community Team
Message 2 of 7
Rostam
Tutor
Re: Cannot create backup from NETGEAR GS724TS configuration.
Software version: V5.1.0.2
Boot ver: 1.0.2.0
Hardware version: 00.00.01
Thanks
Message 3 of 7
schumaku
Guru
Any Magic Internet "security" code blocking certain files, extensions, content, JavaScript, ... on your computer, or on a Proxy?
Message 4 of 7
DaneA
  @Rostam,
Just want to follow-up on this.  Kindly try to update the firmware of your GS724TS to the latest version in a ladderized manner.  First, update the firmware from v5.1.0.2 to v5.2.0.5.  Then, update the firmware from v5.2.0.5 to v5.2.0.8 and so on until you update to the latest version which is v5.2.0.11.  Then check if you can now create a backup of the configuration.
You can download the GS724TS firmware versions here
DaneA
Message 5 of 7
Rostam
Tutor
Thank you!
Message 6 of 7
schumaku
Guru
This helped to backup and install the current firmware finally - which allows to backup using current browser then again?
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 1997 views
  • 2 kudos
  • 3 in conversation
Announcements
