- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Cannot tag more than 2 ports on multiple VLAN subnets
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have 2 VLANS and the default management one on pfSense(not tagged on pfSense), only 2 are tagged as VLAN20 and VLAN30
On Netgear GS116EV2 I have the following:
VLAN1(default) - all ports untagged
VLAN20 - ports 5 and 15 tagged (TRUNK) - port 15 is linked to pfSense, and port 5 to Unifi FlexHD AP, the rest of the ports are not members of VLAN20
VLAN 30 - ports 5 and 15 are tagged (TRUNK) - port 15 is linked to pfSense, and port 5 to Unifi FlexHD AP, the rest of the ports are not members of VLAND30
The VLAN 20 and 30 serves as an IOT and GUEST WI-FI, and VLAN1 MAnagement WI-FI
The AP works well with the above config, serving 3 different SSID's
The issue is the following:
I want in addition to link the port 3 on First switch (GS116EV2) with the second switch on port 1- (GS105Ev2) via another trunk port as i was able to understand.
I want the first switch to transmit over the tag VLAN1 and VLAN20
On the second switch the port 5 should have VLAN20 in order that the Smarthings hub to be part of the IOT network, the rest of the ports can remain on management VLAN1.
When I try to Tag port 3 on the first switch, after I hit apply, it won't stay tagged, I cannot add another port as tagged or untagged, or whatsoever.
Can you please help, and explain?
Thanks
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Cannot tag more than 2 ports on multiple VLAN subnets
Add the VLAN [U] or [T] detail to both ends of each trunk (e.g. to the left and the right of the VLAN info on the drawing, and mark the one you can't configure.
Show - from both switches - the Web config for VLAN -> 802.1Q -> Advanced (this mode must be used on the switches) ...
- VLAN Configuration
- VLAN Membership (for each individual VLAN)
- Mark as New
- Bookmark
- Subscribe
- Permalink
