- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
GS105E
- Mark as New
- Bookmark
- Subscribe
- Permalink
Good Evening all,
Im hoping you can help me with my GS105E. Essentially im trying to setup port mirroring, however I dont have the relevant options displayed to me. Ive watched over videosand tutorials and I dont have the options that others do. See me attatched image.
I believe the option to enable htis should be under 'System', however its greyed out and I cannot click on it.
Does anyone have any guidance please?
Chris
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Resolved: Downloaded Version 2.2.9 - Suggest Netgear take a look at the latest version they have for download.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: GS105E
Hello asodjaosdja,
Welcome to the community!
I am unable to view the attached image, if you can send it to me by PM it would be great. Please make sure that you are using the latest utility v2.3.5 and select the switch that you are trying to configure. Follow these steps below to enable port mirroring:
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: GS105E
Hi asodjaosdja,
I receieved the PM and also able to view the image properly now. It appears that the switch is not selected, make sure that the radio button is clicked. Did you follow my advice on making sure that the utility is update to v2.3.5?
Thanks,
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: GS105E
JohnRo,
Many thanks for your quick response. Sorry I should have added, I try and click the radio button but it doesnt register, in other words I am not able to select the switch.
As for the version of ProSafe Plus Config Utility I am using 2.3.5
Any more ideas?
Thanks,
chris
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: GS105E
As a further step I have installed the software onto another machine and am expiriencing the same issue
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: GS105E
Spoke too early...
I can select the device, but after I enter the password it just tells me 'The switch and manager IP address are not in the same subnet!', but doesnt give me the option to change the IP on the switch.
This was my first ever Netgear purchase and quite possibly the last
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: GS105E
Downloaded/uninstalled all manor of versions and I get either the error above, or 'incorrect password'. It is not the wrong password as it is still default and I've had various people try. I change the machine to be on the correct subnet and it still gives me that error.
Repackaged and awaiting courier to return it for a refund. Wont be purchasing Netgear for the replacement
