Orbi WiFi 7 RBE973
Reply
GS110EMX manual step up speed for port 9 and 10 error
VinceDucat
Tutor
hello on the GS110EMX last firmware when i try to fix the speed of those port (9 and 10) trought the GUI. the menu only propose 10Mb 100Mb 1000Mb but those port are 2.5G 5G 10G...
is it a bug
Message 1 of 6
schumaku
Guru
Re: GS110EMX manual step up speed for port 9 and 10 error
For Ethernet link speed above 1000M, link negotitation is mandatory. Thus it's intentional.
Why do you think you need to fix the link rate?
Message 2 of 6
VinceDucat
Tutor
Hell il would like to force at 2.5G beacause i have a problème with wax206 ans gs110EMX some time the connexion beetween wax206 and the network was lost : my solution was to unplugged wire between wax206 and gs110amx and replugge and the connexion came back.. so perhaps a porbleme of autonégociation...
Message 3 of 6
schumaku
Guru
@RaghuHR can Netgear look into this possible interop issue with the WAX206 and the GS110EMX please?
Message 4 of 6
VinceDucat
Tutor
WAX206 is used as AP and connect to the GS100EMX via WAN/LAN port (yellow)
Message 5 of 6
VinceDucat
Tutor
Is any answer to this probleme ?
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 1307 views
  • 0 kudos
  • 2 in conversation
Announcements
