Orbi WiFi 7 RBE973
GS110TP MIBs
wuwu84
GS110TP MIBs
Hi Netgear support,
can you please provide me a link to download the MIBs for GS110TP? I need it to switch ON/OFF poe admin mode via snmp.
Thank you very much!
Model: GS110TP|ProSafe 8 ports gigabit PoE smart switch
Message 1 of 4
Accepted Solutions
schumaku
Guru
Re: GS110TP MIBs
https://netgear.com/support/  -> type your model, find your switch, head to downloads, and find  https://www.netgear.com/support/product/GS110TP.aspx#download ... pick the MIB for the current firmware.
There isn another thread where a community member shows that the POWER-MIB are available on the GS110TP - "POWER-ETHERNET-MIB, part of the private MIB tree of Netgear, it doesn't implement the IETF OID"  https://community.netgear.com/t5/Smart-Plus-Click-Switches/GS310TP-snmp-poe-disable/m-p/1796579/high...
Message 3 of 4
All Replies
DaneA
NETGEAR Employee Retired
Re: GS110TP MIBs
@wuwu84,
You may download the GS110TP MIB on this link.  The link will expire within 2-3 days.
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
DaneA
NETGEAR Community Team
Message 2 of 4
schumaku
Guru
Re: GS110TP MIBs
Message 3 of 4
wuwu84
Re: GS110TP MIBs
Hi schumaku,
thanks for that.
It works great with .1.3.6.1.4.1.4526.11.16.1.1.1.3.1
Smiley Very Happy
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1666 views
  • 1 kudo
  • 3 in conversation
Announcements
