Orbi WiFi 7 RBE973
Reply
GS116Ev2 - Can't log into Prosafe - Command is not supported by agent
Blair2201
Tutor
I've just installed a new switch GS116Ev2 and have trouble logging into ProSafe.   I open the utility, enter the default password and receive a message "Command not supported by agent".
Has anyone experienced the same thing and found a fix?
Model: GS116Ev2|ProSafe Plus 16 ports gigabits switch
Message 1 of 3
Accepted Solutions
JeraldM
NETGEAR Employee Retired
Re: GS116Ev2 - Can't log into Prosafe - Command is not supported by agent
Hi @Blair2201,
It's most likely that the management mode is set to Web browser only if your firmware is v2.6.0.43 or newer (please check the release notes here).
That being said, you'll need to access the switch using a web browser instead (please refer to this KB article on how to do so).
JeraldM
NETGEAR Community Team
Message 2 of 3
All Replies
JeraldM
Hi @Blair2201,
JeraldM
Message 2 of 3
Blair2201
Tutor
Thank you JeraldM.  Much appreciated.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 2005 views
  • 2 kudos
  • 2 in conversation
Announcements
