Reply
GS308EPP daisy chain
sachinchain80
Hi All
I have a GS348 (48port), i will add a GS324 (24port) and presume they should daisy ok?
I will need an 8 Port POE switch as well-would the GS308EPP daisy ok or another netgear 8 port switch-unmanaged is fine
Thanks
Message 1 of 3
schumaku
Guru
Re: GS308EPP daisy chain
Yes, of course. Depends what you expect performance-wise through the complete daisy-chain however.
Message 2 of 3
sachinchain80
Thank you
Basic small business, only running low perfm PC and a couple of POE access points
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 463 views
  • 0 kudos
  • 2 in conversation
Announcements
