- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
GS310TP power plug size
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm in need of a replacement power supply for a GS310TP. I have seen several 54V power supplies that could work, but I've seen different sized barrel plugs. So i was hoping someone may be able to provide that info.
I tried looking at all the documents for both switches and power supplies on Netgear's site. However if it's there I haven't found it.
Any help would be appreciated.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
So I just received the power supply I ordered from my-adaptor.com and it is working great. Description says it is 6.0mm x 3.0mm, so slightly different then mentioned above. However it fits snug, not tight, with no wiggle.
This is the PS I ordered https://www.my-adaptor.com/332-11001-01-m-76199.html
Hope this helps others since I have seen people on other sites also looking for a PS for this switch.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: GS310TP power plug size
Welcome to the Community!
48V/54V DC adapters should have a 6.5 x 3 mm size for it's output plug.
HTH
- Mark as New
- Bookmark
- Subscribe
- Permalink
Marc_V,
Thank you for the information. I believe I found one that will work. I'll post an update if it does as I have seen a few people looking for power adaptors recently.
- Mark as New
- Bookmark
- Subscribe
- Permalink
