Reply
GS316EPP not linking up at 1Gig
pnarayanswamy
Hi Folks
I recently purchased Netgear GS316EPP and I am connecting it to a Netgear ProSafe 8 Port Gigabit switch and the links is not negotiating to 1G. it always remains at 100Mbps. Is this a bug or does anyone in this thread have experienced this and if yes what did you do?
I also connected a Netgear NightHawk 8000P to this device and I see that negotiating to not more than 100Mbps
Appreciate any help
Thanks
Poorna
Message 1 of 7
Accepted Solutions
Guru
Re: GS316EPP not linking up at 1Gig
make sure to use high quality cat 5e cables or cat 6 cables. I've seen sketchy cat 5e cables not connect at gigabit rates.
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 3 of 7
All Replies
kjknet
Luminary
@pnarayanswamy
Try a different cable. Push the cable plugs harder into the ports.
Kris K
Message 2 of 7
Guru
Message 3 of 7
schumaku
Guru
What device is connected - make, model, version, OS; ... ?
The cable has four pairs (eight strands), or just two pairs?
Message 4 of 7
pnarayanswamy
I agree with you. It seems that the cable I  am using though shows all pins connected 1-8, and looks perfect but the cable definitely is bad. First look I thought the crimping was bad and re-crimped to get the same pathetic problem. Replaced the cable with another and I see Gig speed. I unfortunately have to rewire my whole home!!! Sad but have to redo!!!
I used cable from Amazon - FastCat Cat6 and I encourage folks not to buy this cable. Reviews in Amazon was great but I and one more who has given a review (which I missed) are victims of this shady cable. Requested Amazon for a refund but Amazon being Amazon directed me to Vendor saying please contact vendor, as return date expired!!. God knows where they source these cables and what they will do. Amazon must do some stringent quality checks!!!!
Message 5 of 7
pnarayanswamy
it is a straight cable 1-8 maps to 1-8
Orange White / Orange
Green White / Green
Blue White / Blue
Brown White / Brown
The link tester shows all 8 links pass like a charm but the cable (FastCat Cat6) is definitely a menace
https://www.amazon.com/fastCat-Cat6-Ethernet-Cable-1000ft/dp/B07JB4W6MF?psc=1&pd_rd_w=mZh2c&content-...
Warning to all Network Enthusiasts ==> PLEASE DO NOT BUY THIS PRODUCT!!!! FROM AMAZON!!!
Message 6 of 7
Guru
Really check your ends carefully. I've seen the wires nicked when stripping off the outer cover for making ends and that cause cables to still pass a continuity tester but fail actual usage. (made this mistake myself a time or 2).
It sucks because your tester will say everything is fine because its just testing that the copper is intact. Its just once you start putting data down it that there's issues.
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 1172 views
  • 0 kudos
  • 4 in conversation
Announcements
