Orbi WiFi 7 RBE973
Reply
GS324tp open a port for unfiltered connection ?
mToddh
GS324tp                 Is it possible to totally open a port for unfiltered access?
Message 1 of 4
Accepted Solutions
schumaku
Guru
Re: GS324tp open a port for unfiltered connection ?
Unless there are ACLs or multiple VLANs configured all ports resp. the VLANs are transparent. Not sure what use case you are behind here.
Message 2 of 4
All Replies
schumaku
Guru
Message 2 of 4
mToddh
We are having problems VOIP phones to the switch,  They are working fine with the old dumb switches.
Message 3 of 4
schumaku
Guru
Disable the AutoVoIP protocol and OUI capabilities - otherwise you might find VoIP device associated to the VoIP VLAN.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1266 views
  • 1 kudo
  • 2 in conversation
Announcements
