Orbi WiFi 7 RBE973
Reply
GS348T VLAN
KPP-IT
GS348T VLAN
Hi there
I have read from https://community.netgear.com/t5/Smart-Plus-and-Smart-Pro-Managed/GS324TP-S350-Unable-to-assign-IP-t... that our switch does not support VLAN Routing.
If that is the case, I was wondering how we would be able to use the VLAN that was on the switch to begin with. Would be great if anyone can enlighten me.
Thank you.
Model: GS348T|NETGEAR® S350 Series 48-Port Gigabit Ethernet Smart Managed Pro Switch with 4 SFP Ports
Message 1 of 3
KPP-IT
Re: GS348T VLAN
To add on, we have tried adding a VLAN, in an attempt to segregate the network, following instructions from the tutorials, etc. But since there are no routing options, the VLAN we created does not seem to work, even with our network's IP address. Hopefully I'm not misunderstanding the use of VLAN here.
Message 2 of 3
schumaku
Guru
Re: GS348T VLAN
Each VLAN does create a dedicated - mostly isolated - network.
Access points, router et all require VLAN support to deal with the different networks, different IP subnetworks.
Typically, the routing and security/access control is done on a small business class router much easier.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1051 views
  • 0 kudos
  • 2 in conversation
Announcements
