Orbi WiFi 7 RBE973
Reply
GS728TPPv2 M4100-24PoE+ Port PVID question with two vlans
Budgie4
Tutor
I have set up two vlans with different subnets with dhcp and dns enabled on my UTM.  These are both set on one port on the UTM.
When I connect this port to my switch I have to configure the switch port to receive this connection.
I have set up the port on the switch to connect as U-ntagged on the port and it is a member of both VLans but... I understand I can only set one PVID per port which defaults to 1 but this is usually the case for T-runked ports.
Am I right to use U on the connection to UTM or should it be T?
Message 1 of 2
schumaku
Guru
Re: GS728TPPv2 M4100-24PoE+ Port PVID question with two vlans
You can configure the trunk port for the UTM<->Switch link on both sides as tagged for all VLANs, or you can keep _one_ VLAN untagged with the same PVID obviously.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 476 views
  • 0 kudos
  • 2 in conversation
Announcements
