Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
GS748Tv5 Printer Multicast blocked by Auto DoS
joelphilippage
Hi. I recently pruchased a ProSafe Smart Switch. One of the features I wanted was Auto-DoS detection that shuts off ports that are suspected of a DoS attack. Whenever I enable this, the two Lexmark printers on our network are quickly disconnected. I have contacted support twice. The first time I contacted them, they told me that this feature should be used as a fallback and I should have a firewall in place between the modem and the switch. I have since purchased a ProSAFE firewall and got it set up, but this has not solved the problem.
I contacted them again. They requested I monitor the packets and send them too them, but they have not gotten back to me on a solution. The packets that cause the alert art MDNS or Multicast packets. Here is what one of the packets looks like:
1	0.000000	10.0.53.17	224.0.0.251	MDNS	278	Standard query response 0x0000 PTR Lexmark T430._http._tcp.local PTR Lexmark T430._ftp._tcp.local PTR Lexmark T430._tftp._udp.local PTR Lexmark T430._printer._tcp.local PTR Lexmark T430._ipp._tcp.local PTR Lexmark T430._pdl-datastream._tcp.local
I have changed some of the flooding settings for that port, but this makes no difference. Are these just old printers? Is there a way to add an exception for a port and still have Auto-DoS enabled?
Thanks for the help!
-Joel
Model: GS748Tv5|ProSAFE 48-port Gigabit Smart Switch
Message 1 of 2
Accepted Solutions
DanielZhang
NETGEAR Expert
Re: GS748Tv5 Printer Multicast blocked by Auto DoS
Hi Joel,
Welcome to NETGEAR community!
I just check packets as your mentioned.Smiley Happy
Please try operation as below to work around this case on GS748Tv5.
--Disable UDP port service in Denial of Service Configuration page
The root cause is the special MDNS packets that "Source port must be equal with destination port In MDSN according to RFC6762"
This option "UDP port" in Auto-DoS will drop these special packets and shutdown the port which receive its.
Let me know if this work around don't work.
Daniel.
NETGEAR Employee.
Message 2 of 2
All Replies
DanielZhang
NETGEAR Expert
Hi Joel,
Daniel.
NETGEAR Employee.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 3810 views
  • 1 kudo
  • 2 in conversation
Announcements
