Reply
GS750E Management VLAN ID
DaRocket
Follower
Hi,
I cannot find any option to change the managemnet VLAN ID on the GS750E, surely there must be a way to change it from VLAN ID 1 to something else?
Thanks
Model: GS750E|48 Port Gigabit Ethernet Smart Managed Plus Switch with 2 SFP Ports
Message 1 of 2
schumaku
Guru
Re: GS750E Management VLAN ID
No, there is no way. The design of the Smart Managed Plus switches does not allow to restrict the management to a specific VLAN. Put up some more VLANs, run the switch as a DHCP client ... and you find that random DHCP servers from different subnetworks are able to assign network configurations..Some Smart Managed Plus models (afaik also the GS750E) allow to put up some IP based restrictions on the management - but here again you will find that this is not restricting to a certain VLAN.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 569 views
  • 0 kudos
  • 2 in conversation
Announcements
