Orbi WiFi 7 RBE973
Reply
GS752TXS FP_COUNTER_TABLE Error
pmapp
Morning All,
Switch: GS752TXS (running in a stack of 3 with 10gb DAC)
Firmware: 6.1.0.27
We are getting the following errors constantly:
<11> Oct 8 09:26:15 10.1.0.21-3 DRIVER[53846932]: broad_hpc_drv.c(4253) 7955209 %% unit 0 FP_COUNTER_TABLE entry 1146 parity error
<11> Oct 8 09:26:15 10.1.0.21-3 DRIVER[53846932]: broad_hpc_drv.c(4253) 7955208 %% _soc_xgs3_mem_dma: FP_COUNTER_TABLE.ipipe0 failed(NAK)
<11> Oct 8 09:26:13 10.1.0.21-3 DRIVER[53846932]: broad_hpc_drv.c(4253) 7955207 %% unit 0 FP_COUNTER_TABLE entry 1146 parity error
<11> Oct 8 09:26:13 10.1.0.21-3 DRIVER[53846932]: broad_hpc_drv.c(4253) 7955206 %% _soc_xgs3_mem_dma: FP_COUNTER_TABLE.ipipe0 failed(NAK)
<11> Oct 8 09:26:11 10.1.0.21-3 DRIVER[53846932]: broad_hpc_drv.c(4253) 7955205 %% unit 0 FP_COUNTER_TABLE entry 1146 parity error
<11> Oct 8 09:26:11 10.1.0.21-3 DRIVER[53846932]: broad_hpc_drv.c(4253) 7955204 %% _soc_xgs3_mem_dma: FP_COUNTER_TABLE.ipipe0 failed(NAK)
<11> Oct 8 09:26:09 10.1.0.21-3 DRIVER[53846932]: broad_hpc_drv.c(4253) 7955203 %% unit 0 FP_COUNTER_TABLE entry 1146 parity error
<11> Oct 8 09:26:09 10.1.0.21-3 DRIVER[53846932]: broad_hpc_drv.c(4253) 7955202 %% _soc_xgs3_mem_dma: FP_COUNTER_TABLE.ipipe0 failed(NAK)
<11> Oct 8 09:26:07 10.1.0.21-3 DRIVER[53846932]: broad_hpc_drv.c(4253) 7955201 %% unit 0 FP_COUNTER_TABLE entry 1146 parity error
<11> Oct 8 09:26:07 10.1.0.21-3 DRIVER[53846932]: broad_hpc_drv.c(4253) 7955200 %% _soc_xgs3_mem_dma: FP_COUNTER_TABLE.ipipe0 failed(NAK)
<11> Oct 8 09:26:05 10.1.0.21-3 DRIVER[53846932]: broad_hpc_drv.c(4253) 7955199 %% unit 0 FP_COUNTER_TABLE entry 1146 parity error
<11> Oct 8 09:26:05 10.1.0.21-3 DRIVER[53846932]: broad_hpc_drv.c(4253) 7955198 %% _soc_xgs3_mem_dma: FP_COUNTER_TABLE.ipipe0 failed(NAK)
<11> Oct 8 09:26:03 10.1.0.21-3 DRIVER[53846932]: broad_hpc_drv.c(4253) 7955197 %% unit 0 FP_COUNTER_TABLE entry 1146 parity error
<11> Oct 8 09:26:03 10.1.0.21-3 DRIVER[53846932]: broad_hpc_drv.c(4253) 7955196 %% _soc_xgs3_mem_dma: FP_COUNTER_TABLE.ipipe0 failed(NAK)
<11> Oct 8 09:26:01 10.1.0.21-3 DRIVER[53846932]: broad_hpc_drv.c(4253) 7955195 %% unit 0 FP_COUNTER_TABLE entry 1146 parity error
<11> Oct 8 09:26:01 10.1.0.21-3 DRIVER[53846932]: broad_hpc_drv.c(4253) 7955194 %% _soc_xgs3_mem_dma: FP_COUNTER_TABLE.ipipe0 failed(NAK)
<11> Oct 8 09:25:59 10.1.0.21-3 DRIVER[53846932]: broad_hpc_drv.c(4253) 7955193 %% unit 0 FP_COUNTER_TABLE entry 1146 parity error
I'm not sure when the errors started, but has been ongoing for a couple of months at least.
I'm unable to try a reboot as the stack is in a live environment.
Does anyone have any suggestions or input on the issue?  If any other info is required let me know.
Thanks
Message 1 of 8
Accepted Solutions
JohnRo
NETGEAR Employee Retired
Re: GS752TXS FP_COUNTER_TABLE Error
Hello pmapp,
I don't believe it is common to get these kind of errors on switches. If you can, I suggest to just reboot the stack and see if the errors will continue.
Thanks,
Message 4 of 8
All Replies
JohnRo
Hi pmapp,
Welcome to the community!
I see you are getting some errors on your switches, let me see if I can help you with this. Upon checking, it appears that these might be DMA erors (Direct Memory Access) on the motherboard(s) on one of the switches. This can also be caused by adding another hardware or module.I have some questions for me to be able to help you further:
1. How old are the swicthes?
2. How long have they been stacked?
3. What changes did you make on your network before experiencing these errors?
Looking forward to your response.
Thanks,
Message 2 of 8
pmapp
Hi JohnRo,
Thanks for the reply....
1. The switches are coming almost 3 years old.
2. They have been stacked since day one.
3. There have been no recent config changes, other than tagging\untagging ports for VLANS.
Thanks for your help.
Message 3 of 8
JohnRo
Hello pmapp,
Thanks,
Message 4 of 8
pmapp
Morning, and thanks for your reply.
I'm unable to reboot the stack until next week.
Once done, I'll report back on the outcome.
Thanks
Message 5 of 8
JohnRo
Hi pmapp,
Alright then, we'll be looking forward to your update.
Thanks,
Message 6 of 8
pmapp
Morning,
A reboot of the stack appears to have stopped the errors - all running fine now.
Many thanks.
Message 7 of 8
JohnRo
Hello pmapp,
Nice to know that the stack is back up and working. If you have any more questions we'll be happy to help.
Thanks,
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 8746 views
  • 0 kudos
  • 2 in conversation
Announcements
