Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
GS908E - where is firmaware file ??
gislovbrian
Tutor
Hi, Just bought a  GS908E managed switch to add to my network .
Checked if there was a firmaware update - there was - but no bin file only instructions.
Have I missed something ?
Brian
Message 1 of 6
Accepted Solutions
gislovbrian
Tutor
Re: GS908E - where is firmaware file ??
Thanks for the help, I found out what I did wrong -  updated now.
Brian
Message 3 of 6
All Replies
Guru
it was there when I just downloaded it.
https://www.netgear.com/support/product/gs908e#download
Current setup: CM2000-> RBE973S-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 2 of 6
gislovbrian
Tutor
Brian
Message 3 of 6
Guru
Glad to hear it!
You might mark it solved so others aren't still trying to fix it 🙂
Message 4 of 6
gislovbrian
Tutor
It is these simple things - how do I mark it  - solved ?
Brian
Message 5 of 6
Guru
click "accept as solution" for the solution
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 730 views
  • 1 kudo
  • 2 in conversation
Announcements
