Reply
GSM4352PB - M4300 52POE+ and PSU
sroghen2
Tutor
Hi,
I will be receiving the following switch very soon - model GSM4352PB M4300-52 POE+ with 1000W PSU. (received from a lab decomissioning).
I actually will not require any of the POE features and would like to reduce the power consumption of this unit.
1. Can POE feature be disabled from the menu option in the switch?
2. If no POE features are used, what is the power consumption of this switch?
2. Can i change the 1000W PSU to the 150W PS which is the one shipped with the non-POE version of this switch? (i know i can switch to 550W PSU which is sold for this model but looking to go even lower).
Thx
Model: M5300-52G-POE+ (GSM7252PSv1h2)|Prosafe 48+4 L2+ POE Stackable Managed Switch
Message 1 of 6
Accepted Solutions
sroghen2
Tutor
Re: GSM4352PB - M4300 52POE+ and PSU
Q1 Answered by reading guide: From the Port Power menu, select Enable or Disable to specify whether the port can deliver power.
Message 2 of 6
All Replies
sroghen2
Tutor
Message 2 of 6
BretD
Admin
Excellent! I'm glad you were able to track down the manual and find an answer to your question. Here is a link to the resources page for M4300.
Please click KUDOS or REPLY If you found this helpful.
Message 3 of 6
sroghen2
Tutor
Actually Q2 and Q3 are still unanswered
Message 4 of 6
LaurentMa
NETGEAR Expert
Hi @sroghen2
Thank you for your message. Yes, you can disable PoE globally from M4300-52G-PoE+ 1000W switch menu - either from Web GUI or from CLI. If CLI is the most straightforward (<<no poe>> command in global interface config mode, with all interfaces selected), it is very easy to so in the Web GUI, going to System / PoE - Global Admin disable.
With PoE disabled, your switch power consumption will be like the M4300-52G switch, you can refer to the M4300 datasheet (Tech Specs at the end, Power Consumption paragraph, just before Environmental Spec).
Swapping the PSU isn't needed, and the APS150W will not work actually. The PoE 1G versions only support APS550W and APS1000W. But without PoE, only 12V power is getting used, and the overall power consumption is already similar to non-PoE switches.
I hope this helps!
Laurent Masia
NETGEAR Senior Product Line Manager, Managed Switches
Message 5 of 6
sroghen2
Tutor
Thank you for your response.
I see on Page 49, the 4300-52G switch has a max power consumption of 47.4W. But this is with a 150W PSU.
I will measure the consumption once I receive the 4300-52 POE+ with 1000W PSU, with POE features disabled on all ports whether it matches the above number or close enough. (Not convinced at this time but will know by end of the week).
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 1143 views
  • 1 kudo
  • 3 in conversation
Announcements
