Reply
GSM7352sV2 no ACL out
Thirty7
No abiltiy to ip access-list namehere vlan ## out....
It's in the CLI guide. Is this straight up a bug?
Message 1 of 5
DaneA
NETGEAR Moderator
Re: GSM7352sV2 no ACL out
@Thirty7,
What is the current firmware version of the GSM7352Sv2?  If ever its not yet on the latest version, kindly update it. The latest GSM7352Sv2 firmware is v10.0.0.53 and you can download it here.  Then, check if the same problem will be encountered.
DaneA
NETGEAR Community Team
Message 2 of 5
Thirty7
It doesn't much anyways as I replaced with an HPE ProCurve and extended ACL's are working in the needed directions.
Message 3 of 5
Thirty7
Looks like the forum sofware won't upload my .png screen shot.
GSM7352Sv2 48-Port Gigabit Layer 3 Stackable Managed Switch with 2 10G SFP+ port, 10.0.0.53, 01.00.35
Message 4 of 5
DaneA
NETGEAR Moderator
@Thirty7,
Thanks for your response.  I suggest you to open a chat or support ticket with NETGEAR Support here at anytime for further investigation on the GSM7352Sv2.
DaneA
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 662 views
  • 0 kudos
  • 2 in conversation
Announcements
