Orbi WiFi 7 RBE973
Reply
GSS116E + LAG + VLAN(s)
vishparakala
How do I go about adding a LAG to a VLAN or VLANs in the GSS116E.
This seems straightforward in the GS108Tv2 but I don't see an option in the GSS116E.
Model: GSS116E|ProSafe 16 ports gigabits Click switch
Message 1 of 4
Accepted Solutions
TheEther
Guru
Re: GSS116E + LAG + VLAN(s)
Judging from the manual, I think you just need to put all of the member ports in the VLAN.
Message 2 of 4
All Replies
TheEther
Guru
Message 2 of 4
XavierLL
NETGEAR Employee Retired
Hi ,
On the Plus Switches you don´t configure the LAG VLANs on the VLAN Membership side,
You just need to make sure that all ports that belongs to the same LAG have the same VLAN configuration.
Hope it helps!
Xavier Lleixa
NETGEAR CBU PLM
Message 3 of 4
vishparakala
Thanks All.
That worked perfectly well !
Regards
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1759 views
  • 0 kudos
  • 3 in conversation
Announcements
