Orbi WiFi 7 RBE973
Reply
How do I update the bootloader to version V1.6.0.2-VB
Dennis-L
Follower
Where can i find the update to update the bootloader to version V1.6.0.2-VB?
Model: GS105Ev2|ProSafe Plus 5 ports switch
Message 1 of 3
schumaku
Guru
Re: How do I update the bootloader to version V1.6.0.2-VB
Can't see the screenshot yet - does the Web UI access challenge to upload the bootloader? Check earlier firmware builds - use "View previous versions" under the current firmware. However, the last one I can locate is GS105Ev2_loader_V1.4.0.5-VB.bin which came with v1.5.0.4.
Somehow I think we had this question before - you have to different GS105Ev2 switches, where the newer came with  V1.6.0.2-VB?
Could be a manufacturing or minor hardware change requiring a newer bootloader.
Probably somebody from Netgear can answer and give some insight on the difference or the lack of availability of the  V1.6.0.2-VB bootloader for download.
Edit: Same on the GS105PE - later manufactured devices come with V1.6.0.2-VB:
Bootloader VersionV1.6.0.2-VB
Firmware VersionV1.6.0.6
The last available bootloader is on this older device, v1.5.0.5-VB became available some firmware releases ago:
Bootloader VersionV1.4.0.5-VB
@YeZ can you challenge the switch engineering please? This could explain the oddities we see on the GS105PE under some conditions.
Message 2 of 3
YeZ
NETGEAR Expert
NETGEAR Expert
The bootloader version difference should not cause firmware behavior difference. Will check with the engineers.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1909 views
  • 1 kudo
  • 3 in conversation
Announcements
