Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
How set to MAC Based ACL on GS724Tv4?
Dongmin
Follower
Hi, My name is KIM.
I have question about GS724Tv4 MAC Based ACL.
1. How set to MAC Based ACL on GS724Tv4 about below situation?
     - GS724Tv4 ------ many device
     - I want set default "Deny all devices using MAC Based ACL"
     - And I want add "permit each devices using MAC Based ACL"
2. What is mean "MAC Mask"?
     - 00:00:00:FF:FF:FF, 00:00:00:00:00:00, etc
     - each device : 00:00:00:00:00:00
     - device all : 00:00:00:FF:FF:FF
     - I want explain about MAC Mask.
Thank you.
Model: GS724Tv4|ProSafe 24 ports Gigabit Smart switch
Message 1 of 2
Retired_Member
Not applicable
Re: How set to MAC Based ACL on GS724Tv4?
Hi @Dongmin
Welcome to Community!
For #1:
By default, there is one rule that to deny all;
So you only need add rule to permit the specific MAC address.
For #2:
In MAC Mask field:
An F means that the bit is not checked, and a zero in a bit position means that the data must equal the value given for that bit.
For example, if the MAC address is aa:bb:cc:dd:ee:ff, and the mask is 00:00:ff:ff:ff:ff, all MAC addresses with aa:bb:xx:xx:xx:xx result in a match (where x is any hexadecimal number). A MAC mask of 00:00:00:00:00:00 matches a single MAC address.
For detailed infor, please refer to UM document at here
Hope it helps!
Eric
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 610 views
  • 1 kudo
  • 2 in conversation
Announcements
