- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
How to raise fan speed on XS708T
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is it possible to raise the fan speed at say 100% ?
Currently is 21% giving MAC t=42° and PHY t=51°.
Thanks to all replies.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
UPDATE: The Noctua NF-A4x20 PWM is an absolutely perfect fit for this, comes with all you need, and makes this switch 100% silent while keeping temperatures in check. Excellent recommendation, thank you.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: How to raise fan speed on XS708T
Hi fcorbelli
Welcome to the Community!
No, it's not.
We design our switches with best tradeoff between perceived Noise and Meantime Between Failure (MTBF) reliability - thanks to best in class componentry. NETGEAR is one of the only few displaying MTBF in datasheets, because of its excellent hardware.
Your numbers below look good, well under max temperatures we also display in GUI (web interface).
Currently our software doesn't allow manual fan settings: by default and per design our switch operates quietly even at full power thanks to its temperature- and load-based fan-speed control.
I hope it helps!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you for response.
I have replaced stock fan (too high pitched for SOHO) with a much larger one (150mm vs 40mm), PWM-controlled one, running at 270 rpm (at 21%).
What is the "target" temperature? Is 50-60° range good enough ?
With regards, Franco Corbelli
- Mark as New
- Bookmark
- Subscribe
- Permalink
You can see it when you log in, directly on System Information page: Scroll down to the Temperature Sensors section. You should see the maximum values for each sensor.
I'm glad you don't report issues, you may know that hardware modifications void warranty as per http://www.netgear.com/about/warranty/
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you for help, but silence is much more valuable than warranty 😉
- Mark as New
- Bookmark
- Subscribe
- Permalink
The Community would always be there to help you, in any ways.
Can you indicate the exact model and part-number of the new fan(s) and any detailed information?
- Mark as New
- Bookmark
- Subscribe
- Permalink
First try:
Noctua NF-A4x20 PWM http://noctua.at/en/products/fan/nf-a4x20-pwm replacing the stock fan.
Good (low pitch noise) but sadly unhappy positioning of the air outlet (directly on my concrete wall).
I suggest to test this combo, seems very promising: small price and 2 minute screwdriver work.
Second:
Noctua NF-A15 PWM, 140mm fan (drilling the metal case, a very quick-and-dirty job)
http://noctua.at/en/products/fan/nf-a15-pwm
- Mark as New
- Bookmark
- Subscribe
- Permalink
Very interesting! Thank you for sharing.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@fcorbelli wrote:First try:
Thank you very much for this recommendation!
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
