- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Inter VLan Traffic with conditions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi all
I am hoping for some advice
We are replacing our current GS724Tv3 with XS724T
We are downsizing from 3 to 2
I have been tasked with configuring the new two
I am having some difficulty with the inter-Vlan traffic and was hoping for some guidnace or advice.
A small breakdown of our networks
We are a webHosting Company and have many clients.
The Two new Switches will be our main Core Switches
We have basically 3 Egress options for the internet.
We have Unfiltered(direct internet connection) VLAN1
We then feed to a DDOS system and back into the switches as a Filtered Network VLAN2
This i have working fine.
My issue comes with our backup internet line. Currently sitting in vlan1 and being monitored and managed via a proxy system the ISP controls.
I need to feed VLAN2 from this connection if the main line goes down bringing the ddos line down.
How would i setup the inter-vlan routing for this case?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Inter VLan Traffic with conditions
To set up inter-VLAN routing for your scenario, where you need to feed VLAN2 from a backup internet line in case the main line goes down, you can follow these steps:
1. Connect the backup internet line to one of the ports on your new core switches, preferably on the switch designated as the primary one.
2. Create a new VLAN for the backup internet line, let's say VLAN3. Assign an appropriate VLAN ID and IP subnet for this VLAN. For example, you can use VLAN ID 3 and subnet 192.168.3.0/24.
3. Configure the interface connected to the backup internet line on the primary switch as an access port in VLAN3. This will allow traffic from the backup line to enter the switch and be routed to other VLANs.
4. Configure inter-VLAN routing on both core switches. This will enable communication between VLANs. Ensure that the routing table is properly configured, and the default gateway points to the appropriate VLAN interface for each VLAN.
5. On the primary switch, configure a default route pointing to the main internet line (VLAN2) as the preferred path for internet traffic. This will ensure that traffic from VLAN2 uses the main line by default.
6. Configure a static route on the primary switch for VLAN2 traffic, pointing to the backup internet line (VLAN3). This static route should have a higher administrative distance (metric) than the default route to prioritize the main line.
7. Test the setup by simulating a failure on the main internet line. You can disconnect the main line temporarily to verify that VLAN2 traffic automatically switches to the backup line.
By following these steps, you can achieve the desired behavior of feeding VLAN2 from the backup internet line when the main line goes down. Keep in mind that the specific configuration steps may vary depending on the switch model and firmware version you are using. It's always recommended to consult the documentation or seek assistance from the manufacturer or a networking professional for detailed configuration guidance specific to your equipment.
Regards;
David Johnson.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you David That is exaclty what i need
I will test and report back
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi David
You mention having both primary and backup plugged into Primary/CoreA
We had planned on putting Primary in A and Backup in B
This covers us for any switch issuesif core A fails
Does that complicate things.
