Reply
JavaScript error on Device View tab on GS724Tv4 switch
favoptic_tech
I have recently upgraded our GS724Tv4 switches to firmware 6.3.1.34 and now the Device View no longer needs a working Java plugin which is great.
But I noticed a JavaScript error in the console:
VM153:11 Uncaught SyntaxError: Unexpected token < in JSON at position 11245
at JSON.parse (<anonymous>)
at parseTextMenu (deviceview.js:787)
at DeviceView.createContextMenu (deviceview.js:878)
at deviceview.js:1123
and the Device View is indeed limited to just a graphical representation of the switch with active ports -- no context menus.
Anyone else notice this problem? I have to presume that this is a bug.
Thanks,
Colin
Model: GS724Tv4|ProSafe 24 ports Gigabit Smart switch
Message 1 of 6
schumaku
Guru
Re: JavaScript error on Device View tab on GS724Tv4 switch
The ubiquitous drop of the browser cache for images and files and/or a forced reload does not help?
Message 2 of 6
favoptic_tech
No, doesn't help. Also, the error message in Firefox is different, but same position in the code.
SyntaxError: JSON.parse: expected ',' or ']' after array element at line 11 column 10 of the JSON datadeviceview.js:787:29
    parseTextMenu http://fav-pio-sw1.favoptic.com/base/js/deviceview.js:787
    createContextMenu http://fav-pio-sw1.favoptic.com/base/js/deviceview.js:878
    waitForImages http://fav-pio-sw1.favoptic.com/base/js/deviceview.js:1123
Message 3 of 6
favoptic_tech
How do I get Netgear to look at this? We don't believe in paid support -- especially when all I went to do is alert them to a bug that potentially affects all customers.
Message 4 of 6
DaneA
NETGEAR Moderator
@favoptic_tech,
I inquired your concern to the higher tier of NETGEAR Support and got a feedback that it would be best that you open a support ticket for further investigation.  Kindly open a support ticket with NETGEAR Support at anytime here and state your concern as well as you may include a link to this community thread.
DaneA
NETGEAR Community Team
Message 5 of 6
favoptic_tech
I managed to open a support ticket for this a month ago or so. Eventually it was passed over to the engineering team, so hopefully they're looking into this and will come up with a fix. As far as I can tell, the support ticket is still open, so presumably they are working on it.
Thanks for getting back to me!
/Colin
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 678 views
  • 0 kudos
  • 3 in conversation
Announcements
