Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
MS510TXPP logout issue
--shaun--
I'm seeing an issue with an automated solution controlling a MS510TXPP.
I have the following workflow:
  • login
  • navigate to port details page
  • get port status and speed
  • logout
this is repeated for each port but after checking 3 ports I start having issues logging in.
I've managed to get around my issues mostly by adding a 10 second sleep after I logout. but this does still fail but not often.
everything is running in a docker container hosted on linux the docker container is also running linux I'm controlling the interface using selenium and chrome executed in python, I have some other nether switches that working fine no issues and no sleep required .
the switch is running firmware 6.7.0.42
Message 1 of 6
JohnC_V
NETGEAR Moderator
Re: MS510TXPP logout issue
Hi --shaun--,
Welcome to our community! 🙂
It seems that you are having issues with your switch. I suggest upgrading the firmware of the switch first to the latest version and then resetting it to factory default. Let's see if the issue goes away after the firmware update.
John
NETGEAR Community Team
Message 2 of 6
Retired_Member
Not applicable
@--shaun--
Bad idea. Forget it. I hope you are not trying to do it for some business critical infrastructure.
Message 3 of 6
--shaun--
Hi John,
we also have another switch that has the later version of firmware install and it also has the same issue with out the 10 second sleep in the logout code.
thou we do have another netgear switch which using the same method of controlling does not need the 10 second sleep
Thanks
Shaun
Message 4 of 6
--shaun--
What makes it a bad idea?
it's not for some business critical infrastructure. it's to automate some testing of another product.
Message 5 of 6
Retired_Member
Not applicable
@--shaun--
The screen design or flow can change any time. A screen layout or flow is not an API so there is no guarantee of any kind.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 1079 views
  • 0 kudos
  • 3 in conversation
Announcements
