Orbi WiFi 7 RBE973
Multiport LAG Across Two GS108T Switches
stevefxp
Apprentice
I have a 4 port LAG coming from my firewall, down to two GS108T switches. Each switch is connected to the LAG on ports 1 and 2. Port 8 connects each switch to the other. Is this a supported distributed LAG configuration for the GS108T?
Model: GS108Tv2|ProSafe 8 ports gigabit smart switch
Message 1 of 4
Accepted Solutions
schumaku
Guru
Re: Multiport LAG Across Two GS108T Switches
No - because of the two GS108T are not stackable devices.
Message 2 of 4
All Replies
schumaku
Guru
Message 2 of 4
stevefxp
Apprentice
Thanks for that info...can the GSM7228PS be stacked using the front gig ports or can I only do this using the stacking modules that go on the back?
Message 3 of 4
LaurentMa
NETGEAR Expert
Sure, you can use the front 10G ports. Just need to enable stacking mode on these ports (configured mode). Then a reboot of each switch will be needed to have it as running mode. When the first switch is half way booting, connect the cables in between and you can boot the second switch. After both will have booted and discovered each other, your new stack will be formed and ready for distributed link agreegation between the two. You will create your 4-port LAG across both switches, and connect your firewall there.
Hope this helps,
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1873 views
  • 3 kudos
  • 3 in conversation
Announcements
