Reply
NETGEAR GS728TX (S3300-28X) Stencils
PinkyDU-Z
Follower
Hi, will there be stencils for this switch added anytime soon please? There are PoE models in current Netgear Stencils pack, but not the non-PoE ones. I tried to modify S3300-28X-PoE+ Stencil for this one but that does not work well at all...
I have both PoE and standard switches on site so really need to refer to both precisely in the network map.
An update woudl be very appraciated, thanks!
Model: S3300-28X (GS728TX)|ProSafe 24 ports stackable smart switches
Message 1 of 2
schumaku
Guru
Re: NETGEAR GS728TX (S3300-28X) Stencils
To my knowledge, NTGR does not have own stencils - much more you can get in contact with https://visiostencils.com/mcs/NETG.html FMI.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 533 views
  • 0 kudos
  • 2 in conversation
Announcements
