TPHBRK
Apr 22, 2025Aspirant
RSTP Designated Root
Main switch GS752TP
G28 Fiber uplink to GS752TP (Switch B)
G26 Fiber uplink to GS724TP (Switch D)
Switch B
G25 fiber link to non-netgear switch (Switch C)
Switch C does not link to anything else
Switch D
G25 Fiber uplink to Main switch
Randomly the Main switch will disable port G26 and it doesn't resume normal until I reboot Main switch.
I noticed in STP settings that the designated root is the non-netgear switch (Switch C) and it is currently selected running smoothly. How does that switch get designated when it has no other path to the rest of the network?
I didn't notice what the designated root was when it disables G26 port on the main switch.
I found this entry on the "Switch D":
<182>1 2025-04-22T08:11:20.114-4:00Z 192.168.109.67-1 LLDP-6-NEIGHBOR_DEL proto_lldp.c(4308) %% Neighbor deleted on port GigabitEthernet25: Chassis ID 3C:37:86:CB:9A:AD, Port ID g26
<182>1 2025-04-22T08:11:19.454-4:00Z 192.168.109.67-1 STP-6-PORT_STATE proto_stp.c(820) %% Port GigabitEthernet25 moving from Forwarding to Disabled
<181>1 2025-04-22T08:11:19.444-4:00Z 192.168.109.67-1 TRAPMGR-5-STP_NEW_ROOT ksi_snmp.c(484) %% This bridge has changed to be the root bridge.
<181>1 2025-04-22T08:11:19.244-4:00Z 192.168.109.67-1 TRAPMGR-5-PORT_LINK_DOWN ksi_snmp.c(230) %% Interface GigabitEthernet25 link down
This is the entry on the main switch coinciding with the same time:
<182>1 2025-04-22T08:11:20.540-04:00 192.168.109.249-1 LLDP-6-NEIGHBOR_DEL proto_lldp.c(4321) %% Neighbor deleted on port GigabitEthernet26: Chassis ID 94:18:65:43:9C:CB, Port ID g25
<182>1 2025-04-22T08:11:19.790-04:00 192.168.109.249-1 STP-6-PORT_STATE proto_stp.c(820) %% Port GigabitEthernet26 moving from Forwarding to Disabled
<181>1 2025-04-22T08:11:19.550-04:00 192.168.109.249-1 TRAPMGR-5-PORT_LINK_DOWN ksi_snmp.c(230) %% Interface GigabitEthernet26 link down
The main switch should really be the designated root but i don't know how to configure that. I'm also guessing the non-netgear switch needs to have STP disabled on it.
Can someone help me understand what is happening? And what are the implications of a non-netgear switch with STP enabled?
Time to learn and understand RSTP (essentially the same for the basic STP)?
The Switch Bridge Priority must be carefully planned and set on every switch.
https://en.wikipedia.org/wiki/Spanning_Tree_Protocol#Rapid_Spanning_Tree_Protocol
Sometimes, I'd wish Netgear would publish such clear KB articles on RSTP configuration, as available with other vendors e.g. here Network Switch - Configure RSTP (Rapid-Spanning-Tree-Protocol) in a ring topology
- TPHBRKAspirant
appreciate the links for education. Question related more towards Netgear, when i have a switch that is non-netgear branded and it has RSTP enabled, does disabling the STP status on the Netgear port where this non-netgear switch is connected drop BPDU traffic so the other netgear switches essentially ignore the non-netgear switch?
