Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Switch GS728TP: POE Admin enable/disable via SNMP
tc43
Greetings Community,
i need to enable/disable POE on switchpots adimistratively from remote. I cannot use the buit in feature like scheduling, hence i would like to go ahead with snmpset.
What is the correct OID to touch interface X in that manner and the value for on/off?
Which MIB is relevant for this task?
Thanks a lot and best regards!
Model: GS728TP|ProSAFE 24-port PoE Smart Switch with 8 PoE+-port
Message 1 of 3
Accepted Solutions
DanielZhang
NETGEAR Expert
Re: Switch GS728TP: POE Admin enable/disable via SNMP
Hi Tc43,
Welcome to NETGEAR community!Smiley Happy
We can use the public MIB POWER-ETHERNET-MIB to control PoE status through SNMP.
Please reference following screenshot to deploy.
May the solution help you.Smiley Happy
Thanks,
Daniel.
NETGEAR Employee.
Message 2 of 3
All Replies
DanielZhang
NETGEAR Expert
Hi Tc43,
Thanks,
Daniel.
NETGEAR Employee.
Message 2 of 3
tc43
Hello Daniel,
thanks a lot! I got it running with your hint!
Best regards!
Chris
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 3689 views
  • 1 kudo
  • 2 in conversation
Announcements
