- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
UniFi APs restart every 5min when GS310TP is in the same network
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
I have a strange problem. I just integrated a GS310TP in my network. I also have a few Access Points from UniFi that are not behind to the GS310TP but directly connected to my core switch. Even though since I connected the GS310TP the APs are restarting every 5 minutes.
It seams like I manged to fix this by deactivating the STP on the GS310TP (at least no restart for 15 mins now).
How could STP cause such issues? Is there any config I have to tune (I didn't change the factory defaults)?
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: UniFi APs restart every 5min when GS310TP is in the same network
Hi Chris,
Can't imagine on how disabling STP (which acts network-wide) should have an impact on some APs restarting or not. If there would be any kind of flood caused by a network loop (and STP [better use RSTP for the complete network] would prohibit by shutting down some ports, an AP should not reboot.
Probably the APs can't reach the management network - which is by default the untagged VLAN 1 for UniFi - and for whatever recovery attempt?
On your other post, I see various config changes different from the default.
-Kurt.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
my comment about the factory defaults was only refering to the STP settings.
The affected UniFi devices were already set to the VLAN10 as management VLAN.
It really puzzles me, that the STP-settings on the netgear switch, which doesn't connect the affected APs to the router or the controller, causes the resets...
I'll do some more testing over the weekend.
Regards
