Reply
Upload configuration failing
budgrantrules
Hi, I'm trying to upload the configurations of our switches via the Smart Control Center. Some work fine and the .cfg file is saved. Others come back with the error in image 3. Image 1 shows the log and you can see successful runs and failures. Image 2 shows all of the switches in SCC and green marks are ones that let me upload the configuration file and red did not work (returning error on image 3).
Thanks for your help.Netgear error 3.PNGNetgear error 2.PNGNetgear error 1.PNG
Model: GS752TPv2|48-Port Gigabit Ethernet PoE+ Smart Managed Pro Switch with 4 SFP Ports (380W)
Message 1 of 2
budgrantrules
Re: Upload configuration failing
Not sure what is going on with the images. They were initially .png files so I converted to .jpg. I'll post again here. You'll figure out the error, switches and logs.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 402 views
  • 0 kudos
  • 1 in conversation
Announcements
