NasKar
Mar 09, 2021Aspirant
VLAN1 and GS108Ev3
I have a few Netgear GS108Ev3 switch connected together with tagged ports.
1) Is it ok to turn off VLAN 1 on all the ports and untag the VLANs I want to come thru on each port?
2) Can I connect a Cisco switch to the GS108Ev3 on a port where all the VLANs are set to tagged? Passing all the VLANs to a trunk port on the Cisco? Do I have to have VLAN 1 active for this to work?
NasKar wrote:I have a few Netgear GS108Ev3 switch connected together with tagged ports.
802.1q mode one might guess here.
NasKar wrote:1) Is it ok to turn off VLAN 1 on all the ports and untag the VLANs I want to come thru on each port?
Yes, of course.
NasKar wrote:2) Can I connect a Cisco switch to the GS108Ev3 on a port where all the VLANs are set to tagged?
Sure, create all the VLANs required and configure the port (for the trunk) to be tagged.
NasKar wrote:Passing all the VLANs to a trunk port on the Cisco?
Done as per the above.
NasKar wrote:Do I have to have VLAN 1 active for this to work?
Definewhat you understand as "have VLAN 1 active".
- NasKarAspirant
Thanks for the reply. I didn't get a email that you responded. Sorry about the late reply.
I think I finally have it working. Can ping on all the devices on VLAN 5 from the computer connected to Cisco switch on untagged port VLAN5.
The Native Vlan on the trunk port of the Cisco has to be VLAN5 and the PVIDs for all the ports on the netgear have to be on 5 as well.
So the PVID is equivalent to Cisco Native VLAN?
NasKar wrote:So the PVID is equivalent to Cisco Native VLAN?
Half of it. Netgear has some design allowing the config of asymmetrical VLANs (breaking the 802.1q common understandings). There are two controls affected: The setting of the port to (one on the 802.1q context!) [U]natagged VLAN participation defining which VLAN frames are flowing out of the switch untaggged, and the PIVD which does define the VLAN untagged incoming frames to the switch will be assigned to.
- Apr 13, 2023Retired_Member
