Reply
XS708E Plus Switch Problems connecting to Admin Page
pgjscottieuk
Guide
Purchased a second hand XS708E downloaded ProSafe Plus Configuration Utility V2.7.8 the switch showed up let me assign a static IP address but that's all switch selection nothing can see what firmware its running 1.00.12 it seems to be working connected to XS512EM and a Mac with an OWC Thunderbolt 3 10gbe adaptor
On the back of the switch there is a label ISCSI SWITCH does this mean the switch has been modified in some way which is why I can not access the other settings through the uliity
I did roll back and try a different version of the utility but that didn't make any difference
Any help advice would be much appreciated
Message 1 of 7
Accepted Solutions
Marc_V
NETGEAR Moderator
Re: XS708E Plus Switch Problems connecting to Admin Page
Alright so when you select the XS708E and then click on Apply nothing happens? or
After clicking Apply the IP settings shows up?
Have you tried providing the Password on the IP settings and then hitting Apply? If yes, what happens after that?
If the Tabs are not really showing up you may want to try doing a Factory reset first.
If possible post the screenshot of what is happening after providing the password or after selecting the switch and hitting apply.
Many thanks
Marc_V
NETGEAR Community Team
It's what you do that defines you
NETGEAR Community User Guidelines
Message 6 of 7
All Replies
Marc_V
NETGEAR Moderator
@pgjscottieuk
Can you post a screenshot of what you are seeing? Does the utility not giving you out any tabs? (Network, System, QoS) or the utility is not showing the switch after giving it a static IP?
Marc_V
Message 2 of 7
pgjscottieuk
Guide
Message 3 of 7
Marc_V
NETGEAR Moderator
When you choose the Switch and click apply what happens? Have you tried entering the password and hitting apply? the default password is "password"
Marc_V
Message 4 of 7
pgjscottieuk
Guide
The options arn’t there double clicked on 708 switch nothing only tab that does anything is IP as screen shot shows
Message 5 of 7
Marc_V
NETGEAR Moderator
Many thanks
Marc_V
Message 6 of 7
pgjscottieuk
Guide
After launching the Pro safe Plus Utility highlife the switch clicked apply as per your suggestion password window opened entered the default password bingo got into switch reset to default job done thank you for your help
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 289 views
  • 0 kudos
  • 2 in conversation
Announcements
