Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
XS712T Jumbo Frames
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2013-08-14
09:38 AM
2013-08-14
09:38 AM
XS712T Jumbo Frames
Hi all,
It appears that Im having some issues with enabling jumbo frames on my XS712T. I have set the max frame size to 9216, and yet if I try to ping a device connected to the switch with anything over 1500bytes it times out. I have directly connected both devices and have no issue pinging with larger packets which makes me think its the switch blocking the packets.
Is there anywhere else I need to enable jumbo frames on the switch other than "maximum frame size"?
Thanks all
Thanks all
Message 1 of 3
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2014-11-03
03:07 PM
2014-11-03
03:07 PM
Re: XS712T Jumbo Frames
Hi,
Did you ever get to the bottom of the issue with jumbo frames on the XS712T? I have exactly the same issue. If I set the MTU > 1500 in VMware the connection is blocked by the XS712T.
If I plug the cables into a standard HP Procurve the connection works for an MTU of 9000... Its just odd.
Any ideas?
Thanks
Any ideas?
Thanks
Message 2 of 3
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2014-11-03
06:52 PM
2014-11-03
06:52 PM
I did not, I simply set my jumbo frames at 8000 on my workstations and servers and it seems to be working though not sure why I had to set them that low...
I would give that a try and report back, when Im at the office tomorrow I can look in to further settings if your still having issues.
Thanks,
Rudy
Thanks,
Rudy
Message 3 of 3
