Orbi WiFi 7 RBE973
Reply
gs308epp vs gs310tp Which one is better?
nikolasgr
Follower
Hello can you please help me decipher which one is best?
Data Sheet GS350series_DS.pdf
https://www.downloads.netgear.com/files/GDC/GS305EP/GS305EP_GS305EPP_GS308EP_GS308EPP_GS316E_GS316EP...
apart from the obvious extra ports...
Model: GS310TP|NETGEAR® S350 Series 8-Port Gigabit PoE+ Ethernet Smart Managed Pro Switch with 2 SFP Ports
Message 1 of 2
Iphie_C
NETGEAR Expert
Re: gs308epp vs gs310tp Which one is better?
Hi @nikolasgr
It depends on your application.
Hardware:
GS308EPP has 8 PoE+ ports with total 123W PoE budget, no SFP ports for uplink.
GS310TP has 8 PoE+ ports with total 55W PoE budget, and 2 SFP uplink ports.
Software:
GS308EPP is a Plus switch, which has VLAN, QoS, IEEE Energy Efficient Ethernet, Port Mirroring, and advanced PoE controls including PoE scheduling and per port PoE control, etc.
GS310TP is a Smart switch, which has all the Plus switch features + ACL, advanced VLAN, IGMP snooping, STP, SNMP, etc.
You can refer to GS310TP datasheet here:
https://www.downloads.netgear.com/files/GDC/smart-switches/S350_Series_GS308T_GS310TP_GS324T_GS324TP...
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1016 views
  • 0 kudos
  • 2 in conversation
Announcements
