Orbi WiFi 7 RBE973
Reply
gss116e Unable to configure
lmcarter
Follower
When I try to configure, I get the following message "the switch and manager IP address are not in the same subnet.  How do I fix this?
Model: GSS116E|ProSafe 16 ports gigabits Click switch
Message 1 of 2
schumaku
Guru
Re: gss116e Unable to configure
I would strongly advise to connect the switch to a LAN like your router with a working DHCP server, and do cold reboot so the DHCP server will assign an IP address in the same subnet. That's much easier then the following ...
If attempting to configure a switch connected direct to the PC, or on a network without a DHCP server, it's required to configure a static IP on that very same IP subnet like default IP 192.168.0.239/24, something like 192.168.0.123 subnet 255.255.255.0 default gateway and DNS like 192.168.0.239 (avoid any "test if the config works"). Take notes so you can revert to the original settings.
Windows  -> How do I set a static IP address in Windows?
MacOS -> Configuring TCP/IP and Proxy Settings on Mac OSX
FMI: What is the default IP address of my NETGEAR Smart Managed Plus, Smart Managed Pro, or Insight Manag...
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 616 views
  • 0 kudos
  • 2 in conversation
Announcements
