Orbi WiFi 7 RBE973
Reply
help. Wifi working (using WAP's) but wired not - through same switch
TrevorJones
Follower
I have a home network set up where I have 8 WAPs and 8 hard wired ethernet points in my house running from a powered hub. The netgear app says everything is working fine but I haven't got wired access. The WAPs are working fine. So I can get internet through the WAPs on WiFi but nothing through the wired connections. They were working fine for months until about 4 pm yesterday. I have tried resets, reboots, swapping wires.. nada
Message 1 of 2
Guru
Re: help. Wifi working (using WAP's) but wired not - through same switch
What WAP's do you have?
What switch is it going through?
What router/gateway are they connected to?
Have you tested where the point of failure is? Tested at the router? Tested at the switch? Then tested each WAP to ensure its all of them versus just one?
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 494 views
  • 0 kudos
  • 2 in conversation
Announcements
