Orbi WiFi 7 RBE973
Reply
limiting egress traffic - CoS - is failling
snuf65
Follower
I have setup CS724T switch, and followed the document:
Rate Limiting / Traffic Shaping
I only need to use 5 ports.
Internet connected with 1 Gbit to port 1 and CoS = 0 and the other 4 port as follows.
I have made the CoS values like this
        port     -  wanted     -     measured   -    CoS value
        port 22  500 Mbit - down 8,2 Mbps  -  CoS 8000
        port 21 350 Mbit - down 5,64 Mbps -  CoS 5600
        port 20  80 Mbit  - down 1,25 Mbps  - CoS 1280
        port 19  70 Mbit - down 1,12 Mbps  -  CoS 1120
If 1 Gbps = 16000 then 500 Mbit must be 8000 etc.
With 1 Gbps on port 1 and CoS = 0, and a PC connected to the other ports one by one, I had the down load written above.
Then I took one port and the CoS as follows, and got the downloads
  port 22  CoS  8000 -  Download 4.65 Mbps
  port 22  CoS  12000 - Download  11,37 Mbps
  port 22  CoS  16000 - Download 15,15 Mbps
Then I tried with port 1 still CoS=0, and the changed the download port 22 to CoS = 0
 And now Download was 1 Gbit
I also tried change CoS a factor 10, and result looks like the same.
  port 21 - down 5,64 Mbps -  CoS 5600
  port 21 - down  0,56 Mbps -  CoS 560
Looks like the values I get is around 60-64 times to small
wanted  500 Mb got 8.2 that gives  500/8,2 equal 61
         70 Mbit / 1,12  = 62,5.
Can someone explain how I get the right value. Max CoS number is 16346, and it gives around 16 Mbps.
I should be around 1.000.000 to give me 1 Gbps
Message 1 of 1
Top Contributors
Discussion stats
  • 0 replies
  • 570 views
  • 0 kudos
  • 1 in conversation
Announcements
