- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
netgear gs724t crash when router connected
- Mark as New
- Bookmark
- Subscribe
- Permalink
i just got a netgear GS724t v3 24port switch and reset it to factory defaults. so now i don't understand why when i connect the switch to the router the switch just decides to light up the entire board and then reboot itself constantly. if i unplug the switch from router then i can access my nas connected to that switch ok. but once the router is plugged into the switch everything lights up and switch reboots constantly.
is there a setting i should be looking at to get this working again? this is my first forray into managed switches. stp was turned on and no vlans were created i don't see a setting to designate port as uplink from router.
boot version 5.0.3.1
software version 4.1.0.9
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @livefastdrvslo,
Welcome to the community! 🙂
The current firmware of your GS724Tv3 switch is the initial release firmware. I suggest you to upgrade the firmware in a ladderized manner. First, upgrade the firmware from v4.1.0.9 to v4.2.0.11. Then, upgrade the firmware from v4.2.0.11 to 4.2.1.5 and so on until you reach the latest firmware version which is 5.4.2.30.
Be sure to perform a factory reset after upgrading the firmware to the latest version then reconfigure the settings from scratch in order to start clean using the latest firmware version. Then check if the same problem occurs.
You can download the firmware versions for the GS724Tv3 switch here.
DaneA
NETGEAR CommunityTeam
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @livefastdrvslo,
DaneA
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: netgear gs724t crash when router connected
thank your sir!....whatever that firmware flash did it fixed the issue. as soon as i did the first one it played ok with the router connected..... such a simple fix....
i'll slowly work my way up to current firmware now.
