Reply
newbie
vicbee
Luminary
newbie
I have a Netgear 8 ports GS108 switch at home. At work they were going to throw away a 24 port FS726T. I'm wondering if I should keep what I have at home or should I take that larger switch? Is the FS726T better (ie. faster and just as easy to manage - doing nothing)? or should I just forget it... ? Thanks for any help.
Message 1 of 3
fordem
Mentor
Re: newbie
The GS108 is an 8 port gigabit switch, the FS726T has 24 fast Ethernet (100mbps) ports and 2 gigabit ports - so you can connect more devices if you need to, but the connections will be slower, although you're not likely to notice the difference in performance. The FS726 is also a SmartSwitch which means it has some degree of management capabilities, but the GS108 is a dumb switch (unless you have the GS108T or GS108e models). Personally I would grab the FS726 and hang on to it.
Give a man a fish, feed him for a day
Teach a man to fish, feed him for life.
Message 2 of 3
vicbee
Luminary
Re: newbie
Thanks for the feedback.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 7053 views
  • 0 kudos
  • 2 in conversation
Announcements
