× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
CPL 1200 not recognized by Genie - speed worse than CPL 1000
philbury
I bought a couple of CPL 1200 to replace CPL 1000 and Netgear Genie cannot detect the model - just showing a circle with a question mark and the word Unknown. I have factory reset them several times, moved them around but nothing. Right clicking only gives security options and that doesn't seem to work. In use I am getting the red light on throughput and have reinstated my older units pending some info from this community...
Message 1 of 3
Re: CPL 1200 not recognized by Genie - speed worse than CPL 1000
Which genie is this? Desktop?
The desktop genie has never recognised newer plugs in my experience.
Did you replace the "base" plug as well as the "remote" plugs?
Netgear abandoned its own software for Powerline devices some time ago. A lot of us use the ZyXel version instead.
PL1200 and PLP1200 Powerline Utility / Netgear Gen... - NETGEAR Communities
Did you find this?
Powerline PLW1000 slow speed unless rebooted? - NETGEAR Communities
Message 2 of 3
philbury
Yes I removed the old units and put only the 2 new ones in to test them
Model: PLP1200|Powerline 1200 Adapter
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 916 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
