Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Desktop does not connect to Netgear modem
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-08-26
11:04 AM
2011-08-26
11:04 AM
I have Windows 7 64 bit.
I bought a Netgear DGN2000 approximately two years ago. It is working well.
Currently, there is good connectivity between my laptop and the modem/router (wired and wireless).
I worked on my desktop this morning, uninstalled some programmes, but must have uninstalled a driver or something.
I inserted the Resource CD, which installs the modem (although it is installed). Then it stalls at some point.
If I troubleshoot, it states “Windows do not detect a properly installed network adaptor”.
Any help please
Any help please
Message 1 of 4
Retired_Member
Not applicable
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-08-26
12:22 PM
2011-08-26
12:22 PM
Re: Desktop does not connect to Netgear modem
You need to reinstall your LAN or WLAN card in the PC. You may have to use another PC go to manufactures web site find you pc model number and OS download files for netwok cards and install them.
You could also try a system restore to restore PC to an earlier date.
Message 2 of 4
Retired_Member
Not applicable
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-08-26
12:58 PM
2011-08-26
12:58 PM
Try a system restore to a earlier date. If that doesn't work go to your PC manufactures web site help.. support.. locate your pc... select OS... copy network card drivers file onto your laptop copy from laptop to desktop reinstall lan card.
Message 3 of 4
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-09-06
07:28 AM
2011-09-06
07:28 AM
I am apologising for only responding now.
I solved the problem- opened the Device Manager and saw that it was a network driver problem. Luckily, I had the motherboard drivers, installed and everything is working now!
Thanks again
Thanks again
Message 4 of 4
Announcements
