- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
GS116v2-no ethernet after power outage; missing some leds ports 1-4, 5-16 are OK
- Mark as New
- Bookmark
- Subscribe
- Permalink
GS116v2, installed June 2012 by professional in new home on-Q panel. After power outage, no ethernet, Port 1 and 2-no leds, port 3-no left led, right led on; port 4-left led OK, no right led, ports 5-16 all leds on. Port 1 cable attached to ISP modem/wifi router - removed from port 1 and attached directly to computer-ethernet OK, so cable OK. Does this indicate problem/failure of ports 1-4? Wifi works, just wired ethernet does not. Surge protection in on-Q panel and a whole house surge protector.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: GS116v2-no ethernet after power outage; missing some leds ports 1-4, 5-16 are OK
I see no replies yet to my original question. I also tried removing cables from the 4 affected ports, then plugged in ethernet cable from router to port 5 of the switch - still no ethernet connections working from ports 5-16. I guess this means if the first 4 ports were damaged by the storm, the remainder of ports will not work and the switch needs replaced?
