Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
HomePlug AV Adapter Kit fun
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-10-05
09:10 AM
2012-10-05
09:10 AM
Hi. I'm new here. I hope you can help...
I just received my Powerline kit - XAVB1004, which includes an XAV1004 4-port switch and an XAV101 adapter. It didn't go well.
When I tried to install the software, I was asked if I wanted to go online for an updated version. I agreed, and installed a downloded version, which it later turned out would not work properly on Windows 7.
Once I'd googled the problem and worked this out, I went to Netgear's XAV1004 support page for a newer version of the setup utility. There were lots of downloads to choose from. I eventually settled on the 3.1.0.4 version, which worked okay. I also downloaded the XAV1004 Firmware update utility 2.0.0.0, which also worked okay.
Looking for more info on the website regarding the XAV101, I was asked if it was v1 or v2. As it says neither on the device, I guessed it is v1. There is no firmware update utility available for download, and there isn't one listed in the start menu after installing any of the setup utilities I tried - contrary to written instructions elsewhere.
So, which is the correct setup utility to use for this combination of hardware and Windows 7? Is there a firmware update for my XAV101? How do I know if it's v1 or v2?
Thanks for reading.
Thanks for reading.
Message 1 of 2
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-10-05
10:21 AM
2012-10-05
10:21 AM
Re: HomePlug AV Adapter Kit fun
just like any of post asking on V# (entire products)
if it does not say model # V# then it is V1 unit
Message 2 of 2
Announcements
