Pinoski2014
Mar 27, 2014Follower
Mbrn3000
:confused:Please help me to setup Netgear mbrn3000 wireless-n router
- WizardJLuminaryFirst of all, make sure your USB modem is listed as compatible with the MBRN3000. You'll find the compatibility tables here: http://kb.netgear.com/app/answers/detail/a_id/24141
After that, it's pretty basic. Plug the USB modem into the MBRN3000 and connect wirelessly or wired to the router from a PC and go to http://www.routerlogin.com/ or http://192.168.0.1/ (username is admin and password is password). If you aren't seeing a guided installation right at the beginning, just click Setup Wizard in the menu on the left side. Now follow the instructions, and give us an update if you have any questions. :) - jmizoguchiVirtuosoAll router post are going here
http://forum1.netgear.com/forumdisplay.php?f=32
FYI. In the feature posting for the new topics should go above URL
Follow this setup
http://kb.netgear.com/app/answers/detail/a_id/22697 - WizardJLuminary
jmizoguchi wrote: Follow this setup
That has nothing to do with the MBRN3000. The guide is made for normal routers running Genie. The MBRN3000 isn't running Genie (it's EoL at Smart Wizard) and there are no steps in that KB article regarding Mobile Broadband Settings. - jmizoguchiVirtuosohttp://www.downloads.netgear.com/files/GDC/MBRN3000/MBRN3000_UM_10Jun10.pdf
Step by step instruction is in manual
