Reply
Netgear PL1000 low speeds
Jean_
Follower
Hi, on WiFi connection I used to get 100 down but now using Ethernet via this product, I get around 30-40 download speed. Is this normal? Also, would the connection be better if I used a cat8 Ethernet cable? If so, how many cables would I have to get?
Model: PL1000|PowerLINE 1000 adapter
Message 1 of 3
Re: Netgear PL1000 low speeds
Questions about the PL1000 are best dealt with, and may have been already, in the appropriate section:
Powerline Networking - NETGEAR Communities
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 2 of 3
olympos1625
NETGEAR Moderator
Hi Jean_,
Thank you for reaching out. Powerline adapters allows you to turn the power outlet into a high-speed internet connection. It means that the quality of electrical wiring will be a big factor. May we know if you were able to get a speed of more than 50 Mbps via ethernet or wired to the powerline adapter?
Please do not hesitate to let me know if you need further assistance.
Oliver
Community Team
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 147 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
