Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
PLW1000 Extend Router WiFi for Apple Phone “Mobile WiFi” connectivity
- Mark as New
- Bookmark
- Subscribe
- Permalink
2021-11-11
03:09 PM
2021-11-11
03:09 PM
I have a rural property
My Apple phones antenna is unable to communicate with the closest cell tower.
The only building on the 11 acre property is a steel shed.
I have a cellular modem router located inside the shed, which is able to communicate with the distant cell tower via two 4G antenna’s mounted on the shed roof.
To make or receive calls, I set my Apple iPhone to “mobile WiFi”.
That works fine when I’m inside the shed, but my mobile router can’t pass WiFi through the steel wall to the outside of the shed.
I’m looking to resolve the issue by adding. PWL1000 and placing the WiFi component at a power point outside the shed.
I need to seamless phone connection whilst walking between the inside of the shed (cellular modem router WiFi) and outside of the shed (PWL1000 WiFi)
I seem to think this will require the PWL1000 to be set as the same said and password.
Is this correct?
Or can someone describe to best setup
Is this correct?
Solved! Go to Solution.
Message 1 of 4
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
2021-11-12
09:11 PM
2021-11-12
09:11 PM
Hey, thanks MichaelK
After investigating and learning oboist “Mesh Systems” I agree that mesh systems look perfectly tailored to my needs of a single broadly expanded network.
So now looking at Netgears:
A) Nighthawk mesh system6
B) AXE11000 WiFi Mesh System (RBKE963)
Thanks for guiding me towards the Mesh System as the correct network solution
JonL
JonL
Message 4 of 4
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
2021-11-11
03:49 PM
2021-11-11
03:49 PM
Re: PLW1000 Extend Router WiFi for Apple Phone “Mobile WiFi” connectivity
Following on:
I haven’t purchased the PWL1000 yet.
I’simply want to make sure the PWL1000 is the right product. By all accounts, it appears to be.
My network skills are only at the “follow these steps” level.
I need to avoid having my “mobile WiFi” call disrupted went I move from one side of the steel wall to the other.
I am also contemplating purchasing some property equipment that can be controlled from my phone, but to work the equipment needs to be connect to the same network as my phone, which is connected to me cellular modem router.
Message 2 of 4
- Mark as New
- Bookmark
- Subscribe
- Permalink
2021-11-12
03:52 AM
2021-11-12
03:52 AM
You can set up the access point plug as you like. But it may not provide the "seamless phone connection" that you want. For that you'd need a Mesh system. Even with the same SSID and password, wifi clients will have to negotiate a fresh connection during the handover from one source to the other.
The PLW1000 is a Powerline plug. It just provides an Ethernet connection between two plugs.You can also use a non-wifi remote plug to feed a conventional wifi access point. In that way you could use a more capable AP.
Message 3 of 4
- Mark as New
- Bookmark
- Subscribe
- Permalink
2021-11-12
09:11 PM
2021-11-12
09:11 PM
JonL
JonL
Message 4 of 4
Announcements
