- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Poor or no connection with PL1010v2
- Mark as New
- Bookmark
- Subscribe
- Permalink
New install. Four PL1010v2 devices. It seems the only way I can make it work is to plug in the devices on the same circuit. That does me absolutely no good. My house wiring is pretty much up to code, standard 120 vac 100 amp with 3rd wire ground.
Does anyone have any way to improve signal transmission through the service box? If not, the Powerline adapters will have to go back.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
They might have to go back and a different method used.
If they connect on the same circuit is means they're working.
The problem with powerline devices is they're sensitive to interference. Once you're on different circuits, that interference gets much worse.
Things that can cause interference:
high draw appliances
old/bad/poorly done wiring
Poorly made electronics that inject interference
cheap/bad cell phone chargers
gfci outlets
arc fault breakers (found on newer homes)
surge protectors
electronics that are going bad.
Its difficult to troubleshoot powerline because once you're on seperate circuits, it can literally be anything in your home. I had a microwave going bad once that anytime it ran it shut down my powerline network. I just happened to notice it once after several months of headaches fighting it dying. Sometimes you can try going around and unplugging everything you can to see if it helps.
or you can try something like moca adapters (ethernet over coax) which tends to have higher speeds and less interference.
or even a mesh wireless solution if your house is condusive to it.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
gfci outlets
surge protectors
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Poor or no connection with PL1010v2
Thanks. I had come to that conclusion, too. They're boxed up to return to Amazon when the weather breaks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hopefully the solution you try next works better!
Powerline devices aren't for everyone home because of the interference issues
