× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Power line adapter red connection to router
Rob519
Follower
So I just bought the product in question and it’s pick a plug connection light is red on both the one in my room connected to my computer, and the one that’s connected to my router. Is this an issue with the adapter or the router,modem? My router is a standalone btw, my modem is separate if that makes a difference, also I use Comcast.
Model: PLP1200|Powerline 1200 Adapter
Message 1 of 2
Re: Power line adapter red connection to router
@Rob519 wrote:
....it’s pick a plug connection light is red on both the one in my room connected to my computer...
That is a sign of a poor connection between the plugs over the mains circuit.
What happens if you put the plugs near each other on the mains circuit?
If they still look red then either you have faulty plugs or, less likely, your mains circuit could use an electrician's attention.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 803 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
