× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
PowerLINE 1200 Adapter Ethernet Cables
burmesecat
Initiate
Two questions: 1) What is the maximum length of ethernet cable that can be used to connect the PowerLINE 1200 Adapter to a home network WiFi router?    2) What categories of ethernet cable (e.g. 5, 5e, 6, or higher) can be used for this connection?  Thank you.
Message 1 of 3
Accepted Solutions
Guru
Re: PowerLINE 1200 Adapter Ethernet Cables
I'd use a cat 5e of decent quality or cat 6.
You can run up to 300 ft of cable
Message 2 of 3
All Replies
Guru
Message 2 of 3
burmesecat
Initiate
Thank you plemans.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 645 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
